English
FAQ: Why are temporary Spatial Analyst results saved to the Profiles folder when saving the map document?
Question
Answer
This is fixed in ArcGIS 8.2.
When you save the map document, any temporary results from analysis will be saved into your working directory, which is set on the General tab of the Options dialog box.
