English
Problem: Convert Labels to Annotation generates no labels in the map
In ArcMap, when using Convert Labels to Annotation to create annotation in the map, no annotation is created.
Cause
The layer is based on x,y coordinate data and the source table does not have a unique, non-null, indexed field. An index field is required to perform many layer operations in ArcMap including converting labels to map annotation. An index field is not required to convert x,y layer labels to Geodatabase annotation.
Solution or Workaround
Either add an index field to the x,y layer source, or convert the labels to Geodatabase annotation instead of map annotation.
To add an index field to the x,y layer source table, follow the steps outlined in this topic:
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/20463' target='_blank'>How To: Enable Select by Attribute on an OLE DB table</a>
To convert the labels to Geodatabase annotation, in the Convert Labels to Annotation dialog box under Annotation storage options, select 'In a database'.
[O-Image] Convert Labels to Annotation
Related Information
