English
How To: Use the GENERATE command in DAK
Summary
The manual lack specific usage and syntax information, and there is no Online help for the command.
Procedure
The syntax for the GENERATE command for DAK is as follows:
Code:
GENERATE [cover] {sml_file}
Generate adds features to a coverage by entering feature coordinates at the keyboard or from a file.
[cover] The coverage to which features will be added. If no coverage exists new coverage will be created.
{sml_file} The name of the file containing the appropriate generate subcommands and responses. This file can be used as an alternative to command input.
The GENERATE command shows the prompt:
Code:
Generate>
After the prompt appears the following subcommands may be used to generate tics, lines, grids, points and annotations:
ANNOTATIONS [level] [symbol]
CIRCLES {LABELS / NOLABELS}
COPYTICS [cover]
GRID {LABELS / NOLABELS}
INPUT {TTY / file}
LINES
POINTS
QUIT
SYSTEM {Operating_system_command}
NO Topology has yet been defined for features in the coverage. Use BUILD or CLEAN to create topology for the coverage.
