English
Error: Segment to replace does not intersect an arc
Error Message
When I use the RESHAPE command in ARCEDIT or ARCEDITW, I get the following error message:
"Segment to replace does not intersect an arc"
Cause
Inappropriate use of the RESHAPE command. Most likely the 'reshaped are is not crossing the 'original'.
Solution or Workaround
The PC ArcEdit Users Guide defines the RESHAPE command and reveals
that the 'reshaped' arc must cross or touch the 'original' arc.
