ERROR
When previewing a feature class in ArcCatalog that is stored in Oracle Spatial format, the following error will appear in $SDEHOME/sde.errlog,
"load_buffer error -2028"
There are not enough vertices to create a valid shape. For example, lines require at least two vertices, and polygons require at least four, with the first and the last being in the same place.
This is a data problem. Either there are not enough vertices in the feature, or ArcSDE is rejecting some parts of the feature as invalid, leaving insufficient vertices to complete the feature.
Get help from ArcGIS experts
Download the Esri Support App
