HOW TO
Georeference raster data using known corner coordinates
Summary
The process for georeferencing raster data to a reference layer is documented in the book 'Using ArcMap'. However, it is also possible to georeference raster data to known points without a reference layer.
Procedure
The coordinates to which the raster image will be georeferenced and the coordinate system (projection) of those coordinates must be known before beginning this process.
  1. Open ArcMap with a new, empty map, and add the raster data to be georeferenced to the ArcMap session.
  2. Open View > Data Frame Properties > Coordinate System tab > Predefined, and browse to the Coordinate System of the output coordinates you will use in this process.
    For example, if the output coordinates are in NAD 1983 UTM Zone 15N, you will set the projection of the Data Frame to that coordinate system.
  3. Add the Georeferencing toolbar to ArcMap.
  4. Zoom in to the first point on the raster image that will be used as a control point, then click the Add Control Points tool.
  5. Place the cursor over the first control point in the raster and right-click.
  6. Move the curser slightly and right-click.
  7. Select Input X and Y.
    [O-Image] inputxy for georeferencing
  8. Enter the known output coordinates for this control point and click OK.
    [O-Image] Enter Coordinates for georeferencing
  9. Enter enough points for the desired transformation order.
    For further information on the number of control points needed, refer to ArcGIS Desktop Help: About georeferencing > Transforming the raster.
  10. Click View Link Table to evaluate the transformation.
  11. Click the Georeferencing menu and select the Update Georeferencing option to save the transformation information with the raster.
Article ID:000005501
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
