BUG
Editing measure value for vertices fails with Network I/O Error for HP and RedHat Linux
When ArcMap creates a new feature using the Oracle Spatial Linear Referencing System (LRS), it sets the measures to NAN instead of "0" for HP and RedHat Linux. According to the Oracle 8.1.7 documentation, this would be an invalid feature. The values should be set to either NULL, or some measure.
Cause
On HP, Oracle's OCI does not handle NaN's correctly. Oracle is aware of the issue (TAR# 2232230.996)
On RedHat Linux, the functionality was not ported over by Oracle.
Workaround
Both these platforms will be fixed once the underlying DBMS functionality is available.
Article ID:000005497
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
