English
Bug: Nothing happens when printing with ArcPress in ArcScene
Attempting to print with ArcPress through ArcScene does not return an error, it simply does not print.
Cause
ArcPress has not been activated.
Workaround
Activate the ArcPress extension in ArcScene.
When using an extension, ArcMap or ArcCatalog returns the following error:
Error:
"The extension has not been activated"
Cause:
The referenced extension isn't activated.
Solution:
Activate the extension.
  1. Start ArcMap or ArcCatalog.
  2. Navigate to Tools > Extensions.
  3. Check the box next to the desired extensions.
    [O-image]Tools > Extensions
  1. Click Close.
Related Information
