English
How To: Use NetEngine with MS-VC++
Summary
This document describes the steps for including a reference to NetEngine within my Microsoft Visual C++ development environment.
Procedure
To make the NetEngine compatible with VC++, modify the NetEngine include files by adding the following:
  1. At the top of each file, add:
    #if defined(__cplusplus)
    extern "C"
    #endif
  2. At the bottom of the file add:
    #endif
    There are ten include files in the NetEngine\Include folder that need modification.
    After navigating to C/C++ > Visual Studio > Project Settings > Code Generation, set the Calling convention to __cdecl.
