English
How To: Create a batch file to manage 2 ArcSDE instances installed on the same Windows server
Summary
Instructions provided describe how to create a batch file to manage 2 ArcSDE instances installed on the same Windows server. When working with two instances of ArcSDE installed on the same server from the command line, it is best to have two environments set up. Run a batch file to set up the individual environments.
Procedure
Follow the steps below.
Customize this sample batch file to set up the individual ArcSDE environments:
Code:
echo off
rem Set path to sdebin directory
rem Describe the SDE environment
rem SDETYPE is a unique identifying string for this environment setup
set SDETYPE=NUNDA_ARCSDE802_ORA816
rem SDEDBBRAND should be ORACLE, DB2, INFORMIX, SQLSRVR or COVERAGES
set SDEDBBRAND=ORACLE
rem Where are the SDE utility programs on this system that you will use to access
rem the SDE server? Please note: you must use SDE 3.x utilities on your system
rem to talk to SDE 3.x servers and ArcSDE 8.x utilities for ArcSDE 8.x
rem servers.
set SDEHOME=C:\ArcGIS\arcexe81\arcsde\ora8iexe
rem Set the Oracle SID
set ORACLE_SID=orcl1
rem Add SDEHOME to your path
set PATH=%SDEHOME%\bin;%SDEHOME%\lib;%PATH%
rem C:\arcexe80\arcsde\sqlexe\bin;C:\arcexe80\arcsde\sqlexe\lib
rem Standard SDE connection needs
set SDEINSTANCE=sde8ora8i
set SDEUSERNAME=sde
set SDEPASSWORD=sde
set SDEHOSTNAME=keshequa
rem Set a title for the command window
set SDETITLE=SDE for %SDEDBBRAND%: %SDEHOSTNAME%:%SDEINSTANCE%
echo SDE Host Computer: %SDEHOSTNAME%
echo SDE Instance: %SDEINSTANCE%
echo on
