English
Error: Graphic device must be a monitor
Error Message
When running the PROJDB SML, the following error message occurs:
"Graphic device must be a monitor"
Cause
The CON-CGI command was not executed and the IBMVGA12.SYS driver is not loaded for the display driver.
Solution or Workaround
  1. Execute the CON-CGI command.
  2. Load the IBMVGA12.SYS driver for the display driver.
