English
Error: MAPEXTENT not defined, BND not Found, and Coverage not found
Error Message
The following error message is received when running the PROJDB SML:
"MAPEXTENT not defined, BND not Found, and Coverage not found"
Cause
The associated coverages to the PROJDB SML are not located in the same directory as the SML files.
Solution or Workaround
Make sure the following coverages are copied from the ARC training directory ARCTRN\GETSTART\DATA to the personal directory containing the SML files:
LANDUSE
SOILS
SEWERS
ROADS
