ERROR
AREAQUERY fails with (S_GetLRUBlock) Memory for data type 1 is too low
Error Message
The AREAQUERY command fails with the following error message:
"FATAL ERROR (S_GetLRUBlock)
Bailing out of AREAQUERY"
Cause
The cause for this error is unknown.
Solution or Workaround
Potential solutions:
  1. Lengthen the output subclass name being created by AREAQUERY.
  2. Increase the amount of memory allocated with the OVERLAYALLOCSIZE environment variable. More information on this variable can be found by searching on 'OVERLAYALLOCSIZE' in the Index tab of the ArcDoc online help system.
  3. As an alternative to using AREAQUERY, use UNION to combine the coverages containing region subclass and use REGIONQUERY.
  4. Uninstall and reinstall ArcGIS.
    If uninstalling and reinstalling ArcGIS 8.x, click on the link for special instructions.
Article ID:000005451
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
