HOW TO
Increase the performance of the Object Loader when loading features into Geometric Networks
Summary
Building the Map or Edit Cache over the area that objects will be loaded into can result in a significant increase in the speed with which objects are loaded into the Geometric Network.
Procedure
Because of new functionality that was added at ArcGIS 9.0, the Edit Cache was renamed to the Map Cache.
  1. In ArcMap, zoom to the area into which the objects will be loaded. To do this, add the source data to ArcMap. Right click on the layer in the Table of Contents and select Zoom to Layer.
  2. If your version of ArcGIS is 8.3 or earlier Start Editing and build the Edit Cache. If your version of ArcGIS is 9.0 or later build the Map Cache.
  3. Set the Target Layer to load the objects into and click the Object Loader command.
Article ID:000005435
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
