English
How To: Convert pixel coordinate into map coordinate
Summary
Many user-interactive MapObjects Java applications need to get the location of mouse-click in the map. The location of a mouse-click can be returned from the MouseEvent object in terms of the Map object's pixel coordinate value. To perform various spatial functions, we need to convert this pixel coordinate into a map coordinate. This article outlines the steps to convert a pixel coordinate into a map coordinate.
Procedure
  1. Get the x and y location from the MouseEvent e:
    Code:
    int x1=e.getX();
    int y1=e.getY();
  2. Convert the integer values into double type:
    Code:
    double doubleX1=new Integer(x1).doubleValue();
    double doubleY1=new Integer(y1).doubleValue();
  3. Create a point object in pixel units:
    Code:
    com.esri.mo.cs.geom.Point pixelPoint= new com.esri.mo.cs.geom.Point(doubleX1,doubleY1);
  4. Get the Transform object from the Map and call the transform function:
    Code:
    com.esri.mo.cs.geom.Transform trans = map1.getPixelToWorldTransform();
    com.esri.mo.cs.geom.Point mapPoint= trans.transform(pixelPoint, null);
  5. Get the x and y location in map coordinates from the transformed point:
    Code:
    double mapX=mapPoint.x;
    double mapY=mapPoint.Y
    Call getWorldToPixelTransform function on map object to transform Map Coordinate to Pixel Coordinate.
