English
Error: SE_NO_PERMISSIONS
Error Message
Trying to edit an ArcSDE Table or Layer returns the error:
"SE_NO_PERMISSIONS"
Cause
There are two possible causes for this error:
1. The ArcSDE Table or Layer is registered as versioned.
2. The database user trying to make the edits does not have sufficient privileges on the Table or Layer.
Solution or Workaround
-- If the Table or Layer is registered as versioned, create a new edit state to edit the data. Please refer to the ArcSDE developer help for instructions on how to edit versioned data using the C and Java APIs.
-- If the user has insufficient privileges on the Table or Layer, have the owner grant this user insert, update, and delete privileges.
Related Information
