English
Problem: sdeimport on Tru64 fails on non Tru64 sdeexport files
The function sdeimport on ArcSDE 8.1.2 Tru64 will not work correctly.
Cause
A 64-bit related problem, sdeimport on ArcSDE 8.1.2 Tru64 will not work correctly if the sdeexport file was generated on a platform other than Tru64.
Solution or Workaround
Install the QFE for ArcSDE 8.1.2 for TRU64 from the link below. Download "Oracle 8i Import/Export Patch for Tru64 UNIX".
This problem has been fixed in ArcSDE 8.2.
    Related Information
