English
Problem: Data shifts after upgrade from ArcSDE 3.0.2 to 8.1.2 for Tru64
** Fixed at ArcSDE 8.2 **
After upgrading from ArcSDE 3.0.2.2 to ArcSDE 8.1.2 on Tru64 data is shifted.
Cause
After upgrading from ArcSDE 3.0.2.2 to ArcSDE 8.1.2, feature classes are shifted to the left or bottom of the viewing area in ArcCatalog.
Solution or Workaround
Set the extent of the data back to its original value using the SDE administration command:
sdelayer -o alter with the -E option.
Code:
sdelayer -o alter -l rivers,feature
-E calc -i sde_ora816 -s grendel
-u world -p world
