English
How To: Access an ArcMap layout using the ArcIMS GET_LAYOUT request
Summary
You can serve ArcMap Layouts through ArcIMS (version 4.0 or higher) and access them using the GET_LAYOUT request. Out-of-the-box ArcIMS clients such as the HTML viewer or Java viewer and other clients such as ArcGIS (ArcMap and ArcCatalog), ArcPad, and ArcExplorer Java do not have the built-in tools necessary to access layouts from an ArcMap Service.
Only a custom client can utilize the GET_LAYOUT request to access ArcMap layouts via ArcIMS.
Procedure
There a number of things to keep in mind when using the GET_LAYOUT request.
Related Information
