English
Error: [IBM][CLI Driver] CLI0125E Function sequence error. SQLSTATE=HY010
Error Message
If ArcSDE for DB2 is installed after the Microsoft Windows Security Rollup Package(SRP1) the following error message will occur in the sde.errlog
"[IBM][CLI Driver] CLI0125E Function sequence error. SQLSTATE=HY010 db_open_cursor Open Error (-1).SDE_Database Error: -1 HY010
ODBC Error: HY010"
Cause
Installing the Microsoft Security Rollup Package is changing the behavior of the DB2 CLI function - SQLExecute().
Solution or Workaround
IBM is currently investigating this problem. The work-around is to uninstall the Microsoft Windows Security Rollup Package(SRP1) using the Add/Remove Programs option in the Windows Control Panel.
