English
Bug: TIFF images no longer georeference properly in ArcGIS 8.1.2 or higher
TIFFs that were georeferenced in ArcGIS 8.1 or 8.1.1 no longer georeference properly with ArcGIS 8.1.2 or higher.
Cause
This problem began with ArcGIS 8.1 or 8.1.1. Certain TIFF header tags are interpreted differently, particularly those related to projection and scale. When these tags are read into ArcMap 8.1.2 or higher, the rasters are scaled and referenced incorrectly and do not display in the original location.
Workaround
This can be fixed by using CONVERTIMAGE to edit the header information.
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/22490' target='_blank'>How To: Use CONVERTIMAGE to change or edit TIFF header information</a>
