English
How To: Improve draw speed for DBThemes
Summary
Layer envelopes increase drawing speed when adding or zooming to full extent for SDE layers accessed as DBThemes. SDE 3.x does not automatically calculate a layer's envelope after loading as do later releases. An empty layer envelope forces the SDE client (ArcView 3.x in this case) to calculate the layer's envelope on the fly, increasing draw time.
Procedure
Use the following SDE Administration Command syntax to modify and/or calculate a layer's envelope.
Code:
sdelayer -o alter -l <table,column> [-E <{empty | calc | xmin,ymin,xmax,ymax}>][-i <service>][-s <server_name>][-D <database>] -u <DB_User_name> [-p <DB_User_password>]
The -E flag has three options:
Code:
empty
Sets the layer envelope to empty.
Code:
calc
Calculates the layer envelope.
Code:
xmin,ymin,xmax,ymax
Sets the envelope to the specified values.
