PROBLEM
iPlanet Web server won't start after installing and configuring Metadata Explorer or Service Administrator
After installing and configuring Metadata Explorer or ArcIMS Service Administrator, iPlanet Web server won't start, and ArcIMS Diagnostics are not successful.
Cause
There is a typographical error in the ArcIMS Installation Guide's instructions for modifying iPlanet's web-apps.xml file.
Solution or Workaround
  1. In a text editor, open iPlanet's web-apps.xml file.
    On Windows:
    <iPlanet Installation Directory>\https-<localhost>.<domain>.com\config\web-apps.xml
    On UNIX:
    <iPlanet Installation Directory>/https-<localhost>.<domain>.com/config/web-apps.xml.
  2. Scroll to the end of the file and modify the following lines:
    On Windows:
    Code:
    <Web-app uri="/metadataexplorer" dir=" <ArcIMS Installation
    Directory>\Metadata\MetadataExplorer"/>
    and/or
    <Web-app uri="/esriadmin" dir=" <ArcIMS Installation
    Directory>\Administrator\esriadmin"/>
    On UNIX:
    Code:
    Directory>/aims40exe/Metadata/MetadataExplorer"/>
    and/or
    Directory>/aims40exe/Administrator/esriadmin"/>
    so that a lowercase 'w' is used for web-app.
    On Windows:
    Code:
    <web-app uri="/metadataexplorer" dir=" <ArcIMS Installation
    and/or
    <web-app uri="/esriadmin" dir=" <ArcIMS Installation
    On UNIX:
    Code:
    and/or
  3. Save and close the file.
  4. Stop and start the iPlanet Web server.
Article ID:000005306
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
