English
Problem: No features selected when using DBTheme.SelectByRect returned by DBTheme.ReturnExtent
When I use the rectangle that is returned from the ReturnExtent request on a DBTheme to try and select features, no features get selected.
Solution or Workaround
Use the .Scale(1.0) request on the Rect returned and the SelectByRect request should function properly.
