English
Problem: Incorrect library path variable causes a Segmentation Violation
Turning the database access extension on returns:
Error:
"Segmentation Violation."
Cause
Library path variable for Arcview's lib directory is not first in the library path list.
Solution or Workaround
Reference Arcview's lib directory first in the library path variable. See examples below:
For AIX 4.2.1
Code:
LIBPATH = $AVHOME/lib:$ARCHOME/lib
For Solaris 2.5.1
Code:
setenv LD_LIBRARY_PATH $AVHOME/lib:$ARCHOME/lib
Related Information
