English
Problem: Cannot display Digital Charts of the World coverages in ArcCatalog
ArcCatalog does not display Digital Charts of the World (DCW) coverages.
Cause
DCW coverage data is stored in a pre-7.0 coverage format. ArcGIS Desktop does not support pre-7.0 coverages.
Solution or Workaround
Convert the DCW coverage data to a 7.0 coverage format, which is supported by ArcGIS Desktop. ArcInfo Workstation or ArcView GIS can be used to perform the conversion.
  • In ArcInfo Workstation, use the CONVERTWORKSPACE command, which allows a pre-7.0 workspace to be converted to a 7.0 workspace and converts the coverages it contains to the new format.
    Code:
    CONVERTWORKSPACE <PRE-7.0 | NEW> {workspace}
    Arguments
    < PRE-7.0 | NEW> - specifies the output file naming convention.
    PRE-7.0 - converts to the pre-Version 7 workspace file name format.
    NEW - converts to the new Version 7 workspace file name format.
    {workspace} - specifies the workspace to be converted. The default is the current directory.
  • In ArcView GIS 3.x, display the coverage features, click Theme > Convert to Shapefile to convert each coverage feature class into a shapefile. The output shapefile can be used in ArcGIS Desktop.
