Answer
An AutoCAD block is a way of saving repetitive symbols in AutoCAD. For example, in AutoCAD, draw a circle in a box to represent a column in an architectural drawing. That circle in a box can then be saved using the BLOCK command. This saves time by using the block instead of redrawing the column each time it is needed in the drawing.
Article ID:000005244
Software:
- ArcMap 8 x
- ArcMap 9 x
- Legacy Products
