English
FAQ: Will ArcSDE work with Informix patches?
Question
Answer
Informix does not usually supply patches but rather releases these fixes in the next version of the software.
Before applying any patches, back up the database.
If a patch is applied to the database management system (DBMS) and ArcSDE stops working correctly, then it is possible that the patch may have changed something in the database that ArcSDE requires. If this occurs, roll back the patch and try the operation again. If this works, then contact your DBMS company about the patch and its effects on third party applications.
Related Information
