HOW TO
ArcView uses the Plate Carree projection in order to draw unprojected data to a flat monitor. This projection distorts shapes, directions and distances such that a graphic circle drawn in the view does not actually represent a true circle on the ground.
This article provides a script for creating circles within an unprojected view that contains theme data in decimal degrees. The script modifies the shape of the circle so that it actually represents a circle as it would exist on the ground.
Code:
'SCRIPT: "GROUNDCIRCLE.AVE"
'This script works on unprojected DD data
'in an unprojected view. It prompts the
'user for a Lat/Long coordinate and a radius
'in miles. It then produces a shape on the
'View that represents a true circle on the
'ground. The shape will most often NOT look
'like a circle on the View display due to the
'unprojected nature of the themes' source data
'and the Plate Carree projection used by ArcView
'to display unprojected data on a flat monitor.
'GET THE VIEW AND ITS GRAPHIC LIST
theView = av.GetActiveDoc
'theView = av.GetProject.FindDoc("Name of View") 'OR
theGraphicList = theView.GetGraphics
'ENSURE THE VIEW HAS NO PROJECTION
if (theView.GetProjection <> "") then
MsgBox.Warning
("Script only works on unprojected views.",
"Stop")
return nil
end
'MAKE THE PROJECTION OBJECT
theRect = Rect.MakeXY( -180, -90, 180, 90)
thePrj = Sinusoid.Make(theRect)
'GET THE COORDS FROM THE USER TO DEFINE
'THE CENTER OF THE CIRCLE IN DECIMAL DEGREES
pointCoords = MsgBox.MultiInput
("Enter X/Y in DD for center of point",
"Create Ground Circle",
{"Latitude/Ycoord: ", "Longitude/Xcoord: "},
{"40", "-120"})
'CHECK TO ENSURE THAT THE ENTRIES ARE
'CONVERTABLE INTO NUMBERS
if ((pointCoords.Get(0).IsNumber.Not) or
(pointCoords.Get(1).IsNumber.Not)) then
MsgBox.Warning("Incorrect entry","Stop")
return nil
end
'CONVERT THE ENTRIES INTO NUMBERS
unprojCenterY = pointCoords.Get(0).AsNumber
unprojCenterX = pointCoords.Get(1).AsNumber
'ENSURE THAT THE DD COORDINATES ENTERED
'ARE ON THE PLANET SOMEWHERE
if ((unprojCenterX.Abs > 180) or
(unprojCenterY.Abs > 90)) then
MsgBox.Warning("One or more of the input coordinate"+NL+
"values is outside geographics space.",
"Stop")
return nil
end
'RESET CENTRAL MERIDIAN OF SINUSOID PROJECTION OBJECT
'TO COINCIDE WITH THE CENTER OF THE USER'S CIRCLE
thePrj.SetCentralMeridian(unprojCenterX)
thePrj.Recalculate
'MAKE THE POINT, THEN PROJECT IT INTO SINUSOIDAL
unprojCenter = Point.Make(unprojCenterX, unprojCenterY)
projCenter = unprojCenter.ReturnProjected(thePrj)
'GET THE RADIUS FROM THE USER IN MILES
radius = MsgBox.Input("Enter radius in miles:",
"Create ground circle",
"75")
'ENSURE THAT THE ENTRY CAN BE CONVERTED
'INTO A NUMBER
if (radius.IsNumber.Not) then
Msgbox.Warning("Incorrect entry.","Stop")
return nil
else
radius = radius.AsNumber
end
'CONVERT THE RADIUS FROM MILES INTO METERS
radiusMeters = radius * 1609.347
'MAKE THE CIRCLE IN PROJECTED SPACE
projCircle = Circle.Make(projCenter, radiusMeters)
'UNPROJECT THE CIRCLE
unprojCircle = projCircle.ReturnUnprojected(thePrj)
theGraphicCircle = GraphicShape.Make(unprojCircle)
'ADD THE CIRCLE TO THE VIEW'S GRAPHIC LIST
theGraphicList.Add(theGraphicCircle)
'REDRAW THE VIEW
theView.Invalidate
'END OF SCRIPT "GROUNDCIRCLE.AVE"
Get help from ArcGIS experts
Download the Esri Support App
