English
Error: Viewing a map library registered in ArcSDE for Coverages returns: 'Underlying DBMS error'
Error Message
Attempting to view a map library registered in ArcSDE for Coverages returns:
"Underlying DBMS error"
Additionally, features may not show up in the view.
Cause
ArcSDE for Coverages is unable to resolve a path in one of the library tables.
Solution or Workaround
  • Verify that any environment variable used by the library is correctly set and is set as a system environment variable on the machine running ArcSDE for Coverages. Reboot the server so the changes are recognized.
  • Verify that all paths used by the library are correct.
  • If user permissions are restricted for the library, add the $REST user with browse permissions.
