English
Problem: ArcView doesn't draw a point or line event theme on an ArcStorm or ARC/INFO LIBRARIAN route coverage
ArcView does not draw a point or like event theme on an ArcStorm or ARC/INFO LIBRARIAN route coverage.
Cause
ArcStorm and ARC/INFO LIBRARIAN tiles are separated by boundaries. Therefore, route coverages on library layers will cross tile boundaries. ArcView does not retain the route information that is across tile boundaries because of the hidden nodes on the route coverage that distinguish the route from belonging to a specific tile.
Solution or Workaround
ArcStorm databases and ARC/INFO LIBRARIAN coverages must be converted to regular ARC/INFO coverage format before they can be used with ArcView's add event theme functionality.
