ERROR
System Error Type 11
Error Message
"System Error Type 11"
Cause
One possible cause can be low memory.
Solution or Workaround
The following is a list of troubleshooting techniques that may fix the problem.
  1. Find out the current memory usage.
    A. Click Display from the Apple menu.
    B. Click "About this Macintosh" to monitor memory usage.
  2. Increase the memory assigned. In ArcView GIS, click File > Get Info.
  3. Disable any nonstandard memory managers.
  4. Turn off all nonstandard control panels and extensions, such as programs that change or rotate.
  5. Disable sounds, background screens, cursor animators, and screen savers.
  6. Reinstall ArcView GIS with the extensions turned off.
  7. Restart the machine.
Article ID:000005208
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
