PROBLEM
When using the Shapefile to Coverage tool in ArcToolBox, and clicking the OK button, the following error may occur:
"Verify that your instance name and port number are correct in your services file. You do not have WRITE access to <path>."
You do not have write permissions to the directory where the coverage is being saved.
Verify that you have read/write permissions to the directory where the coverage is being saved.
Get help from ArcGIS experts
Download the Esri Support App
