English
How To: Use ArcCatalog to move a raster from one ArcSDE instance to another
Summary
Instructions provided are the steps to copy an ArcSDE raster from one ArcSDE instance to another, using ArcCatalog.
Procedure
  1. Using ArcCatalog, navigate to the Spatial Database connection for the source ArcSDE instance.
  2. Right-click on the raster being moved to the destination ArcSDE instance. Select Export|Raster to Different Format.
  3. In the dialog box, set Save As Type to SDE Raster.
  4. Navigate to the destination ArcSDE instance.
  5. Supply a name for the raster in the target ArcSDE instance and click Save.
Related Information
