English
Problem: PC ARC/INFO annotation shifts when printed in ArcView GIS
After adding a PC ARC/INFO coverage as a theme, annotation shifts when printed in ArcView GIS.
Cause
There are two printer-related causes of this problem. You may have an outdated printer driver, or your printer may be failing to print TrueType fonts as graphics.
Solution or Workaround
  • Verify that you are using the most recent printer driver. If not, download the most recent driver for your printer from the printer manufacturer's Web site.
  • Check the printer driver options to verify that the Print TrueType as Graphics option has been enabled. If it has not, enable it. Then print again from ArcView GIS.
