HOW TO
Change a text string's vertical and horizontal alignment
Summary
Instructions provided describe how to change a text string's vertical and horizontal alignment.
Procedure
  1. Right-click on the text string and select Properties.
  2. In the Properties dialog box, click Change Symbol and then click Properties or Edit Symbol.
  3. Click the General tab, if necessary.
    [O-Image] Vertical Alignment
  4. Click the radio button for the desired vertical and horizontal alignment.
  5. Click OK.
Article ID:000005170
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
