English
Bug: ArcMap Buffer results are incorrect when using projected meters as distance unit
When using projected meters as the distance unit for a buffer operation, the resulting buffer is incorrect.
Cause
This is a known issue.
Workaround
Use meters as a distance unit.
    Related Information
