PROBLEM
ArcMap buffer results are incorrect when buffer distance is an attribute value
Last Published: April 21, 2022
Attribute values can be used as buffer distances in the ArcMap Buffer Wizard. When using the "Based on a distance from an attribute" option the results are sometimes incorrect.
Cause
The is a known issue when buffering multipoint using attribute values as the buffer distance. Only one of the points in the multipoint group will be buffered.
Solution or Workaround
To buffer multipoints using attribute values you will first need to create a temporary layer comprised of single points instead of multipoints. You can use a VBA macro to explode the multipoint features of the layer you wish to buffer into its individual point features. The macro create a new layer - the original multipoint layer is untouched. You can then buffer the new point layer.
  1. Paste the following VBA code in ArcMap.
	Public Sub Explode()
	Dim pClone As IClone
	Dim pDataset As IDataset
	Dim pFeature As IFeature
	Dim pFeatureClass As IFeatureClass
	Dim pFeatureCursor As IFeatureCursor
	Dim pFeatureLayer As IFeatureLayer
	Dim pFeatureWorkspace As IFeatureWorkspace
	Dim pFields As IFields
	Dim pGeometryColl As IGeometryCollection
	Dim pInsertFeatureBuffer As IFeatureBuffer
	Dim pInsertFeatureCursor As IFeatureCursor
	Dim pMxDoc As IMxDocument
	Dim pNewFeatureClass As IFeatureClass
	Dim pPolygon As IPolygon2
	Dim pPolygonArray() As IPolygon
	Dim strNewFeatureClassName As String
	Dim GeometryCount As Integer
	Dim lShapeFieldIndex As Long
	On Error GoTo ErrorHandler
	Set pMxDoc = Application.Document
	'Make certain the selected item in the toc is a feature layer
	If pMxDoc.SelectedItem Is Nothing Then
	MsgBox "Select a feature layer in the table of contents as the input feature class."
	Exit Sub
	End If
	If Not TypeOf pMxDoc.SelectedItem Is IFeatureLayer Then
	MsgBox "No feature layer selected."
	Exit Sub
	End If
	Set pFeatureLayer = pMxDoc.SelectedItem
	Set pFeatureClass = pFeatureLayer.FeatureClass
	'Don't process point layers, they have no multi-part features
	If pFeatureClass.ShapeType = esriGeometryPoint Then
	MsgBox "Point layers do not have multi-parts. Exiting."
	Exit Sub
	End If
	strNewFeatureClassName = InputBox("Enter New Shapefile name:", "New Shapefile")
	If strNewFeatureClassName = "" Then Exit Sub
	'Create a new feature class to store the new features
	'Create the feature class in the same dataset if one exists - shapefiles don't have one
	Set pFields = pFeatureLayer.FeatureClass.Fields
	If pFeatureClass.FeatureDataset Is Nothing Then
	Set pDataset = pFeatureClass
	Set pFeatureWorkspace = pDataset.Workspace
	Set pNewFeatureClass = pFeatureWorkspace.CreateFeatureClass(strNewFeatureClassName, pFields, Nothing, Nothing, esriFTSimple, pFeatureClass.ShapeFieldName, "")
	Else
	Set pNewFeatureClass = pFeatureClass.FeatureDataset.CreateFeatureClass(strNewFeatureClassName, pFields, Nothing, Nothing, esriFTSimple, pFeatureClass.ShapeFieldName, "")
	End If
	'Create an insert cursor
	Set pInsertFeatureCursor = pNewFeatureClass.Insert(True)
	Set pInsertFeatureBuffer = pNewFeatureClass.CreateFeatureBuffer
	'Copy each feature from the original feature class to the new feature class
	Set pFeatureCursor = pFeatureClass.Search(Nothing, True)
	Set pFeature = pFeatureCursor.NextFeature
	Do While Not pFeature Is Nothing
	Set pGeometryColl = pFeature.Shape
	If pGeometryColl.GeometryCount = 1 Then
	'Single part feature, straight copy
	InsertFeature pInsertFeatureCursor, pInsertFeatureBuffer, pFeature, pFeature.Shape
	ElseIf pFeature.Shape.GeometryType = esriGeometryPolygon Then
	Set pPolygon = pFeature.Shape
	ReDim pPolygonArray(pPolygon.ExteriorRingCount)
	pPolygon.GetConnectedComponents pPolygon.ExteriorRingCount, pPolygonArray(0)
	For GeometryCount = 0 To pPolygon.ExteriorRingCount - 1
	InsertFeature pInsertFeatureCursor, pInsertFeatureBuffer, pFeature, pPolygonArray(GeometryCount)
	Next GeometryCount
	Else
	'Multipart feature, create a new feature from each part
	For GeometryCount = 0 To pGeometryColl.GeometryCount - 1
	InsertFeature pInsertFeatureCursor, pInsertFeatureBuffer, pFeature, pGeometryColl.Geometry(GeometryCount)
	Next GeometryCount
	End If
	'Get the next feature
	Loop
	Exit Sub 'Exit sub to avoid error handler
	ErrorHandler:
	MsgBox "An error occurred. Check that the shapefile specified doesn't already exist."
	Exit Sub
	End Sub
	Private Sub InsertFeature(pInsertFeatureCursor As IFeatureCursor, pInsertFeatureBuffer As IFeatureBuffer, pOrigFeature As IFeature, pGeometry As IGeometry)
	Dim pField As IField
	Dim pPoint As IPoint
	Dim pPointColl As IPointCollection
	Dim FieldCount As Integer
	'Copy the attributes of the orig feature the new feature
	Set pFields = pOrigFeature.Fields
	For FieldCount = 0 To pFields.FieldCount - 1 'skip OID and geometry
	Set pField = pFields.Field(FieldCount)
	If Not pField.Type = esriFieldTypeGeometry And Not pField.Type = esriFieldTypeOID _
	And pField.Editable Then
	pInsertFeatureBuffer.Value(FieldCount) = pOrigFeature.Value(FieldCount)
	End If
	Next FieldCount
	'Handle cases where parts are passed down
	If pGeometry.GeometryType = esriGeometryPath Then
	Set pGeometryColl = New Polyline
	pGeometryColl.AddGeometries 1, pGeometry
	Set pGeometry = pGeometryColl
	ElseIf pGeometry.GeometryType = esriGeometryRing Then
	Set pGeometryColl = New Polygon
	ElseIf pOrigFeature.Shape.GeometryType = esriGeometryMultipoint Then
	If TypeOf pGeometry Is IMultipoint Then
	Set pPointColl = pGeometry
	Set pGeometry = pPointColl.Point(0)
	End If
	Set pGeometryColl = New Multipoint
	End If
	Set pInsertFeatureBuffer.Shape = pGeometry
	pInsertFeatureCursor.InsertFeature pInsertFeatureBuffer
	pInsertFeatureCursor.Flush
	End Sub
 See the ArcMap On-line help topic "Creating, editing, and running macros" for more information
  1. Select the layer you want to buffer in the Table of Contents.
  2. Run the Explode macro.
  3. The result will be saved in the same dataset as the selected features, or it the selected layer is a shapefile, then the result will be stored under the same directory as the shapefile.
  4. Buffer the result of the explode using the an attribute as the buffer distance.
  5. Delete the explode result layer.
Article ID:000005145
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
