English
Problem: When using multiple spatial servers, certain requests receive no response
When using multiple spatial servers, incoming requests are cycled through the available spatial servers. If the response from one of the spatial servers is not written to the correct output location, a blank output is received.
Cause
If full paths (C:\arcims\output) were used to specify the output directory instead of UNC paths, spatial server responses are written to the local output directory of the local spatial server machine rather than in the output directory common to all the spatial servers.
Solution or Workaround
Share the common output directory and specify this output directory using UNC paths in the ArcIMS site properties for all spatial servers.
