English
How To: Rotate annotation elements with a user-specified angle
Summary
This document describes how to rotate annotation elements with a user-specified angle.
Procedure
This procedure applies to two types of annotation: Annotation stored in a geodatabase feature class, and annotation stored within an MXD as graphics. If the annotation to be edited is stored as graphics, proceed to step 3.
  1. With ArcMap open, add an annotation feature class to a data frame.
  2. On the Editor toolbar, select Editor > Start Editing.
  3. On the Drawing toolbar, select Drawing > Active Annotation Target, and select the correct annotation layer to edit.
  4. Using the Select Elements tool, click on the annotation element to rotate.
    [O-Image] Select elements
  5. Select the Rotate tool from the Drawing toolbar.
    [O-Image] Rotate button
  6. Press the Shift + A keys to display the angle input box.
    [O-Image] Angle input box
  7. Enter the angle.
    The angle value must be a positive number. Negative values may cause display anomolies.
  8. Press Enter.
Related Information
