English
Problem: HTML Viewer's Find tool returns incorrect query results for ArcSDE for Coverages layers
Queries using HTML Viewer's Find tool incorrectly return all features of the layer.
Cause
The ArcIMS HTML Viewer Find tool does not return correct results when querying an ArcSDE for Coverages layer.
Solution or Workaround
Use the ArcIMS Java Viewers and ArcExplorer Java Edition; they can perform the queries.
If using the Java viewer is not acceptable, modify the query builder used by the Find tool in HTML Viewer so that it uses a query format acceptable by ArcSDE for Coverages.
  • Modify the HTML Viewer query builder for ArcMap Services using ArcSDE for Coverages data.
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/22624' target='_blank'>How To: Modify the HTML Viewer query builder for ArcMap Services using ArcSDE for Coverages data</a>
  • Modify the HTML Viewer query builder for Image Services using ArcSDE for Coverages data.
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/22626' target='_blank'>How To: Modify the HTML Viewer query builder for Image Services using ArcSDE for Coverages data</a>
