ERROR
SE_LOG_ACCESS (-44) The caller does not have permission to access the specified logfile
Error Message
Executing the LAYERLOGFILE command returns the error:
"SE_LOG_ACCESS (-44) The caller does not have permission to access the specified logfile"
Cause
A path was specified in the LAYERLOGFILE syntax. Beginning with the release of version 8.1, all logfiles are stored in tables within the DBMS, not in the $SDEHOME/logs directory.
Solution or Workaround
Do not specify a path in the LAYERLOGFILE syntax.
    Article ID:000005107
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
