PROBLEM
After restarting ArcIMS using Direct Connect for Oracle, services do not run correctly
Last Published: April 26, 2020
ArcIMS services encounters problems upon restarting ArcIMS if any of the services use Direct Connect for Oracle. Various errors are reported in the appserverstatus.log file.
Cause
Parameters for ArcIMS servers and services are saved in the ArcIMSSite.sez file. They are not saved correctly if any of the services utilized Direct Connect for Oracle. If a restart of ArcIMS is required, the Application Server is unable to initialize the ArcIMS servers and services due to the error in the ArcIMSSite.sez file.
Solution or Workaround
Before restarting ArcIMS after a shutdown, follow the procedure below:
  1. <ArcIMS Installation Directory>/AppServer folder, navigate to the ArcIMSSite.sez file and delete it.
  2. Restart the ArcIMS Application Server, Monitor, and Tasker services.
    How To: Stop and start the ArcIMS services or processes
  3. Reconfigure the site servers and services manually using Administrator, Manager, or Service Administrator, or use a batch file or script.
    How To: Manage ArcIMS from the command line
Article ID:000005094
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
