English
Problem: SEARCH and NEAREST options of the Grid RESAMPLE function return the same results
When using the Grid RESAMPLE function, the SEARCH option and NEAREST option return the same results.
Cause
For ArcInfo Workstation Grid and versions of ArcGIS prior to 9.3, the algorithm used for the SEARCH option is the same as the NEAREST option.
The correct algorithm was implemented for ArcGIS 9.3.
This update has not been applied to ArcInfo Workstation.
Solution or Workaround
Where possible, perform the operation in ArcGIS 9.3.
