Answer
The following is the order of the Startup process:
1. Increase file handle count to 255 (Note: function does not work under
Win32s.)
2. Set locale to "C"
3. Set $AVHOME environment variable based on location of arcview.exe program
4. Initialize Neuron Data's libraries. Load ND .dat files
5. Check serial number ($AVHOME/etc/serno)
6. Check timeout date
7. Run startup script
8. Load default codepage
9. Load default.apr
10. Load $HOME/default.apr if present
11. Run Appl.Initialize script
12. Enter main event loop
13. Process garbage collection
14. Check hardware key for hardware key enabled version
15. Exit main event loop
On program load, the following shared libraries get loaded:
Neuron Data libraries/DLLs
ndcore.dll
ndres.dll
ndvgm.dll
ndtkit.dll
ndgw.dll
PC
mtch.dll
gdi32.dll
comdlg32.dll
kernel32.dll
user32.dll
mpr.dll
winmm.dll
msvcrt20.dll
Sunos HP Solaris
libaicore.so.3.0 libaicore.sl libaicore.so
libmtch.so.3.0 libmtch.sl libmtch.so
libavbase.so.7.1 libavbase.sl libavbase.so
libavfeat.so.7.1 libavfeat.sl libavfeat.so
libavgridio.so.7.1 libavgridio.sl libavgridio.so
libX11.so.4.3 libX11.sl libX11.so.4
libdl.so.1.0 libdld.sl libelf.so.1
libcps.so.1.0 libcl.sl librpcsoc.so.1
libc.so.1.8 libc.sl libsocket.so.1
libnls.so.1
libdl.so.1
libc.so.1
libXext.so.0
libw.so.1
libintl.so.1
libmp.so.1
IBM OSF SGI DG
libaicore.a libaicore.so libaicore.so libaicore.so
libmtch.a libmtch.so libmtch.so libmtch.so
libavbase.a libavbase.so libavbase.so libavbase.so
libavfeat.a libavfeat.so libavfeat.so libavfeat.so
libavgridio.a libavgridio.so libavgridio.so libavgridio.so
libX11.a libots.so libX11.so libX11.so.2
libXt.a libc.so libftn.so libXt.so.2
libsvld.a libm.so libXm.so.2
libc.a libc.so libdgc.so.1
libbsd.a libc.so.1
On program execution, the following OI resource files (.dat) get loaded:
$AVHOME/lib/ndcore.dat
$AVHOME/lib/ndres.dat
$AVHOME/lib/nd.dat
$AVHOME/lib/ndvgm.dat
$AVHOME/lib/ndtkit.dat
$AVHOME/lib/ndgw.dat
$AVHOME/lib/avkit.dat
$AVHOME/lib/avcore.dat
