English
Error: Creating a path or coverage name that is more than eight characters causes 'Feature table has error - unable to make theme'
Error Message
Navigating to ArcStorm tiles by clicking on Directories in the Add Theme dialog box returns the following error:
"Feature table has error - unable to make theme"
Cause
At least one path or coverage name is more than eight characters in length.
Solution or Workaround
Modify the path and/or coverage name to be 8.3 compliant.
For a file or path name to be 8.3 compliant, the prefix portion of the name must not be longer than 8 characters. The suffix portion of the name must be 3 characters long exactly. Additionally, the path or file name must not contain special characters, such as, spaces, #, $, and so forth.
