English
How To: TRANSFORM a coverage in ArcCAD
Summary
TRANSFORM is used to change the coordinates of a coverage using an affine or projective function based on control points (tics). TRANSFORM is often used to convert themes created in inches or centimeteres into real-world units represented on a map.
Procedure
Follow these steps in order to transform a coverage:
  1. Define a tic theme that points to the coverage (GIS data set).
    Code:
    DEFTHM
    [O-Image] DEFTHM
  2. Copy this theme to another theme.
    Code:
    Command:COPYTHM
    Input data set (?/MYTIC) Enter or mytic
    Output theme (?): newtic
    Theme NEWTIC is not defined.
    Defining NEWTIC...
  3. Make appropriate edits to newtic.dbf. Substitute new coordinate values for
    the new coordinate system.
    Code:
    Command: modrec
    Theme name (?/<NEWTIC>):
    Updating NEWTIC userid...
    You now have two tic themes, one is pointing to the original GIS data set(MYTIC)and the other is within the empty directory NEWTIC.
    [O-Image] MODREC-WBROWSE
  4. Transform the coverage.
    Code:
    Command: transform
    Input theme (?/<NEWTIC>): mytic
    Transform method (Projective/<Affine>):Affine
    {Note}Use the Projective transformation option ONLY if the features of the input theme were digitized directly from aerial photographs. The accuracy will be defendant on the surface terrain
    For additional information about the TRANSFORM function see the ArcCAD Command Reference book.
