HOW TO
Provides Avenue code to change the current symbol of a theme. The theme must be classified by a single symbol.
Code:
'--- Description: This script will change the current symbol in a single
'--- active theme to a new symbol. The script will prompt for a symbol number.
'--- This symbol number corresponds with the order of the symbol in the respective
'--- symbol list of the Palette Manager. For example, the upper left symbol in the
'--- Marker Palette will be symbol 0, the next symbol to the right will be 1, etc...
'--- Requires: A single active theme that contains one classification in its legend.
'--- Themes that contain multiple classifications will require additional coding.
'--- This script also requires that a View be the active document.
'--- Get the active theme and check the feature type
aView=av.GetActiveDoc
aThList=aView.GetActiveThemes
if (aThList.Count > 1) then
MsgBox.Error("There is more than 1 active theme!","")
exit
else
aTheme=aThList.Get(0)
end
aSrc=aTheme.GetSrcName
aSub=aSrc.GetSubName
'--- Grab the Symbol Window and the appropriate symbol list for the theme
aSw=av.GetSymbolWin
aPal=aSw.GetPalette
if (aSub="Point") then
aSList=aPal.GetList(#PALETTE_LIST_MARKER)
elseif (aSub="Arc") then
aSList=aPal.GetList(#PALETTE_LIST_PEN)
elseif (aSub="Polygon") then
aSList=aPal.GetList(#PALETTE_LIST_FILL)
end
cnt=aSlist.Count
'--- Prompt user for the number of the symbol to be used from the the symbol
list
'--- and provide some error checking.
for each x in 1..10
num=MsgBox.Input
("Please enter the number of the symbol to be used:", "Symbol input","")
if (num=nil) then exit end
n=num.AsNumber
if (n=nil) then
exit
elseif ((n > cnt) or (n < 1)) then
if (x=3) then
MsgBox.Info("Ending Rountine!", "Invalid Inputs")
exit
end
MsgBox.Info
("Please re-enter value.","Value exceeds numbers of symbols in the list")
else
Break
end
end
'--- Now selects the new symbol from the symbol list and clones it. Also the
legend
'--- is selected so that the Current symbol being used can be retrieved.
aCurSym=aSlist.Get(n-1)
aSym=aCurSym.Clone 'Prevents symbols in legend from changing colors
aLegend=aTheme.GetLegend
theSymbols=aLegend.GetSymbols
'--- Grab the current symbol and color used in the legend. This will be applied back
'--- to the new symbol later, and prevents the the default color from being applied
'--- back to the new symbol
Current=theSymbols.Get(0)
aCurColor=Current.GetColor
'--- Replace the old with the new by removing the old symbol from the symbol
list
'--- andthen adding the new one
theSymbols.RemoveObj(Current)
aSym.SetColor(aCurColor)
theSymbols.Add(aSym)
aTheme.UpDateLegend
'------ End Of Script
Get help from ArcGIS experts
Download the Esri Support App
