English
How To: Automatically place map book page number labels
Summary
You can automatically place labels representing bordering maps' page numbers. This example assumes page numbers increase by 1 to the north and by 100 to the east. So the page number of a map to the northwest of map 1245 would be 1146. This example also assumes the map page is 8.5 x 11. Edit the code to work with other page sizes.
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
    For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy this code into the UIButtonControl's click event.
    Code:
    Private Sub UIButtonControl1_Click()
      Dim pMxDoc As IMxDocument
      Dim pActiveView As IActiveView
      Dim pGraphicsContainer As IGraphicsContainer
      Set pMxDoc = Application.Document
      If Not pMxDoc.ActiveView Is pMxDoc.PageLayout Then
        MsgBox "Switch to Layout view in order to use this tool"
        Exit Sub
      End If
      Set pActiveView = pMxDoc.PageLayout
      Set pGraphicsContainer = pMxDoc.PageLayout
      Dim CurrentMap As Double
      Dim NorthMap, NorthEastMap, NorthWestMap, SouthMap, SouthEastMap, SouthWestMap, WestMap, EastMap
      CurrentPageNumber = InputBox("Enter Current page Number")
      If IsNumeric(CurrentPageNumber) Then
        Else
        MsgBox "Invalid page number entry. Try again."
        Exit Sub
      End If
      'Variable List = A list (Bordering Map, X location of text, Y location of text, Rotation Angle)
      NorthMap = Array(CurrentPageNumber + 1, 4.25, 10.1, 0)
      EastMap = Array(CurrentPageNumber + 100, 7.75, 5.5, 90)
      WestMap = Array(CurrentPageNumber - 100, 0.75, 5.5, 270)
      SouthMap = Array(CurrentPageNumber - 1, 4.25, 0.75, 0)
      NorthEastMap = Array(CurrentPageNumber + 101, 7.9, 10.3, 45)
      NorthWestMap = Array(CurrentPageNumber - 99, 0.6, 10.35, 315)
      SouthWestMap = Array(CurrentPageNumber - 99, 0.65, 0.6, 45)
      SouthEastMap = Array(CurrentPageNumber + 99, 7.85, 0.6, -45)
      Dim MapList As Variant
      MapList = Array(NorthMap, NorthEastMap, NorthWestMap, SouthMap, SouthEastMap, SouthWestMap, EastMap, WestMap)
      Dim pTextElement As ITextElement
      Dim pElement As IElement
      Dim pGeometry As IGeometry
      Dim pPoint As IPoint
      Dim pTrans2D As ITransform2D
      For Each Map In MapList
        Set pTextElement = New TextElement
        Set pTrans2D = pTextElement
        Set pPoint = New Point
        Set pGeometry = pPoint
        Set pElement = pTextElement
        pTextElement.Text = "MAP # " & Map(0)
        pPoint.x = Map(1)
        pPoint.y = Map(2)
        pElement.Geometry = pPoint
        pTrans2D.Rotate pPoint, Map(3) * 22 / 1260
        pGraphicsContainer.AddElement pElement, 0
      pMxDoc.ActiveView.PartialRefresh esriViewGraphics, Nothing, Nothing
    End Sub
