English
Error: Cannot open TIGER template file
Error Message
The TIGERTOOL command returns the following error message:
Bailing out of TIGERARC
Bailing out of TIGERTOOL ...
Problem encountered in (RUN_TIGERARC)
Processing incomplete
FATAL ERROR
Terminal hung
Cause
Permissions on the INFO directory located in /arcexe81/template/headers are:
drwxr_xr_
The permissions should read:
drwxr_xr_x
This prevents the user in the 'world' group from executing the instructions in the header folder.
Solution or Workaround
The owner of the installation should change the permissions on the content of the /arcexe81/template/headers directory using the CHMOD command.
chmod -R 755
